1 | |
1 | |
1 | |
1 | |
1 |
I’m trying to work with the tool Requirement Gateway. I started with some examples which are contained in install packet of this tool. I need to connect Gateway with HTML document and manage coverage with another HTML document. I managed to get from HTML document load the list of requirements to Gateway tool. If I tried to open the particular requirement from Gateway than the HTML document was opened on first page always. I can’t set the Gateway for opening the HTML document on particular place, when is described requirement.
My point of view is make some modification for better connection Gateway tool with internet browser.
