NI TestStand Idea Exchange
JesseG
Add link in TestStand Deployment Utility Help For Clarity
Background
Under the Installer Options tab, there is a button called Advanced Options.... (help linked)and then a section for TestStand Specific Settings. This section allows a user to specify where the configuration files will be located when running the TestStand runtime engine on a deployment machine. See screenshot of help discription and then of the utility below:
Help
Screenshot of Deployment Utility Section
Recommended Change to Documentation
When looking at the help documentation, it does not detail what each of the possible destination directories are pointing to. However, if we move to the Distribution Files tab section of the help, there is a detailed list. See this example link here https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/installation-destination-opt...
I recommend making a quick link to this same page to clarify the directories that can be specified for Cfg files.
1 Comment
HarshaBhushan
Status changed to: Under Consideration
