 ChrisHawk
			 on
		08-19-2011
		03:25 AM
			4 Comments (4 New)
			ChrisHawk
			 on
		08-19-2011
		03:25 AM
			4 Comments (4 New)
		We found a need to customize the NI version of this step to give more functionality. Our edits updates to allow multiple response text boxes (up to 10), and we added an option to configure the response to be a list controls rather than simple strings. Just added a Boolean to switch to list box and then the user just gives comma separated list of options with the default item first as the initial response string.
This is a simple change to the step and allows far greater flexibility for the step type (also it was easy to make the step upgradeable from the exiting step version maintainign the functionality if one or no string responses being used).
These features are very useful for collecting all UUT information during PreUUT rather than having to throw up popup after popup or create a custom module with a popup in it. Would be great if these features could be included in the standard NI step.
