NI TestStand Idea Exchange
Al.B
Add option to force the report file path expression to be evaluated after the client sequence executes
A nice feature of reporting is the ability to form the report file pathname using an expression.  However, since the path is resolved before the client Sequence file is executed, you cannot use properties populated in the client sequence file as part of the report pathname. Currently the only way to accomplish this without modifying the model or reportOptions callback is by including the <UUTStatus> macro in the path expression, which enables a portion of the process model which copies the report to a new path based on the result of the UUT:
I propose that we add an option to force the report path to be re-evaluated after the client sequence to allow users to include properties evaluated in the client sequence file in the report file path without needing to include the <UUTStatus> macro.  (basically exposing the ReportOptions.NewFileNameForEachUUTStatus property in the dialog)
Al B.
Staff Software Engineer - TestStand
CTA/CLD
2 Comments
warren_scott
Active Participant
RE-evaluate would be key here.  In our use case we rely on knowing the report file name during execution of client sequence so that we can put extra data files in the same location and with similar names to the final report.
HarshaBhushan
Status changed to: Under Consideration
