1 | |
1 | |
1 | |
1 | |
1 |
The "TestStand - Set Property Value" and "TestStand - Get Property Value" VIs do not have containers as an option.
Is this something that can be added? I can see requiring a cluster input being part of the Set/Get VI that requires the user to match the names/data types of the container. This is similar to Bundle By Name where you have to provide an input cluster.
PS - While you're at it, please add Array of Containers as well.
