NI TestStand Idea Exchange
Elaine_R.
Allow ProcessModel to obtain/retain MainSequence context before & after Call MainSequence step
Status: New
As someone whom regularly maintains custom process models for my team, there are times when I wish to harvest data from 'any MainSequence run' without requiring my individual developers to remember to set specific custom-parameters or 'runstate.root.* or Locals.ResultList[] values within their test programs correctly every time.
It would be great if there were hooks, beyond simple parameter passing, that could allow me to dynamically 'reach in' to active execution context of MainSequence ideally 1x at start and end of MainSequence execution (i.e. just after context fabrication, and just before context garbage collection).
In this way, I could use API to monitor data that usually gets garbage collected before the model can 'see' it.
i.e. if I see they have a local variable in their test, Locals.Debugging_Active == true, perhaps I could catch that at the framework level, and update the report header to say 'possibly not production data!',   even if developer forgot to correctly set the 'is Validation Data' flag that is formally available.
In an ideal world we would have strict process & TS style rules to enforce that all developers must set key variables as part of their executions, but also having a scrappy way to catch test-internal context issues within process model (even if this does break the paradigm of immediately garbage collecting sequence specific internal data) would be a great fall-back strategy for teams where they have 1 or 2 test experts and a much larger pool of non-expert test developers using TestStand.
1 Comment
Elaine_R.
Active Participant
To limit scope of memory preservation, perhaps it could be done for just 1 step, after PreMainSequence callback / before PostMainSequence callback, with a property object similar to Runstate.ProcessModelClient? but instead of containing static file data for the client. it would include execution specific data?
Currently I exploit ProcessModelPostStep to go fishing for 1st or last step 'context' of MainSequence, if I truly need to... but this feels super inefficient 🙂
