1 | |
1 | |
1 | |
1 | |
1 |
For the moment Localization files are to be placed in TestStand public or TestStand user paths.
It should be interesting to move them in a custom directory, which could be configured in the stations options.
(Or defined somewhere in a TestStand project)
Doing so, would simplify the deployment processus ... and Localization files would not be treated as global files, but project files.
=> When you have to handle with many TestStand project, you could have a directory for each project ... with multiple localizations files different by project !
I think the mechanism of file managment of TestStand should be modified, in order ...
Doind so, would simplify the deployment process ... to a simple directory copy !
Thanks.
Manu.net
https://www.ni.com/docs/en-US/bundle/teststand/page/changing-environments.html
