NI TestStand Idea Exchange
pulidotech
Different Numeric Format for Measurements and Limits
Status: Already Implemented
Closing this per Charlie's comment. If you have any other suggestions for improvements, feel free to post back. Thanks!
Trent
Currently in TestStand, for a Numeric Limit Test, the "Numeric Format" applies to both the measurement and the test limits.  I would like to be able to have different numeric formats for the test limits and the measurement.  For example, I might want my limits to be %.2f (e.g. 1.23-2.34) and my measurement to be %.3f (e.g. 1.345) so that I can demonstrate a certain measurement accuracy.
Pulido Technologies LLC
2 Comments
CharlieRodway
Active Participant
You can set the Numeric Format separately for the numeric value and the limits by navigating to the step in the variable pane, right-clicking on Step.Result.Numeric and selecting "Numeric Format..." on the context menu.
Repeat this for Step.Limits.Low and Step.Limits.High to set the formatting as required.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
WireWeaver
NI Employee (retired)
Status changed to: Already Implemented
Trent
