Today the UUT container and other Socket important informations are only available at run time and using long expressions. ![]()
The access to these properties is not valid ate edit time but will be valid only at runtime. ![]()
It would be nice to give a rapid access to these informations using a kind of direct pointer access. ![]()
Something like this would be nice ...
Using always existing properties would also be nice, in order to use Expression intellisense ! ![]()
Thanks a lot.
Manu.
