NI TestStand Idea Exchange
StephenGerads
Execution Globals
Status: Declined
I'm declining this idea due to lack of community support. Also, it's still unclear to me what is different about this idea from TemporaryGlobals
globals scoped to an execution
currently I use RunState.Root.FileGlobals as execution globals
but adding a custom global there normally requires modification of the model
6 Comments
Josh_W
Active Participant
This functionality already exists in TestStand:
RunTimeVariables Property
Since these variables only exist at runtime, you'd need to create them programmatically by calling the API. To access them you could just use the expression Runstate.Execution.RunTimeVariables.<VariableName>.
Josh W.
Certified TestStand Architect
Formerly blue
StephenGerads
It would be nice if the execution variables were not only runtime variables, so they would could be created normally (rather than programmatically) and browsed to normally.
AllenP
NI Employee (retired)
An execution only exists at runtime.  How could they exist outside of that?
StephenGerads
Lots of variables are visible outside of runtime in the expression brower during editing, and it is very helpful that they are.
Bluegraf
Not only these RunTimeVariables are only creatable via the API, they are also terribly bad to see.
The same is valid for TemporaryGlobals which are even tedious to set and get (locals.whatever = TemporaryGlobals.GetValBool("Flag") ... hope I recalled the expression right, have no TS around here).
But worst of all is that the above are only mentioned somewhere deeeeep in the documentation. If you do not know they exist you are not likely to stumble over them.
WireWeaver
Status changed to: Declined
