NI TestStand Idea Exchange
MimiKLM
Feature request: allow to change the names of the measurement in multiple measurement step type.
Status: Declined
I'm declining this idea due to lack of community support.
To change the step name the command Step.Name is commonly used.
However, if the step contains multiple measurements, changing their names dynamically is impossible.
It would be good if this opportunity would exists.
3 Comments
Elaine_R.
Active Participant
last I checked, you could dynamically set names for multiple numeric limit test measurements... it isn't a pretty expression, but you can get there...
it'd be something like Step.Result.Measurement[0].Name = "ABC"  ? Is this what you were looking to do?
WireWeaver
NI Employee (retired)
Status changed to: Declined
ee-jallen
In can be done dynamically with Step.Result.Measurement[0].Name = "ABC", however if your dynamic names are coming from the Step module call itself then you need to add Step.Result.Measurement[0].Name = "ABC" to a SequenceFilePostStep callback to be compatible with the On-the-fly option of the report generator
