NI TestStand Idea Exchange
MimiKLM
Feature request for sequence file editor: Expand and collapse functionality for every step type which has to have END step type.
Exactly as in subject.
I thought that it will be good if the developers could collapse blocks of code which are in between of the Flow Control or/and Synchronisation step types.
I think about the mechanism we know already from TestStand which hides block of code: i.e. Setup, Main, Cleanup section in the sequence, or it can hide variables. It is a little "+" and little"-" to expand the content of the type of variables.
The types of steps I think of were mainly types from Flow Control and some types from Synchronisation. It would be good if for example we could collapse If-Else-ElseIf-End, Select-End, Case-End, While-End, DoWhile-End, etc statements
I think this functionality could improve the readability of the sequence, and helps the developers to have a better view on the whole sequence.
3 Comments
crossrulz
Knight of NI
Duplicate:Folding Editor for Control Flow
Elaine_R.
Active Participant
i still vote that these conditional blocks don't go far enough 🙂
http://forums.ni.com/t5/NI-TestStand-Idea-Exchange/Expandable-Mode-for-Sequence-Execution-Display/id...
I'm still dreaming of the day that any subsection is collapsable 🙂
WireWeaver
NI Employee (retired)
Status changed to: Duplicate
