Hello all TestStand fans,
For my recent project i had to modify the frontEnd callback.
=> According to the TestStand help, the only path where this file can be created is in TestStand default path or in the corresponding user path.
.... But no where else !!!! ![]()
It would be nice to be abble to configure the frontEndCallback path in the configure options !
=> Doing so, the path of this callback could be placed everywhere ! (In the configuration path would be nice !)
=> Doing so, it would be possible to create a frontendcallback for each configuration !
I am a TestStand developper, a NI partner, not a TestStand end user.
My work is to provide custom sequencer for my customer.
On my computer i had to manage many different sequencer !
I think that if it is impossible to do so, today, is because this callback is loaded before the "Station configuration" is loaded ?
My ideas should be applyed to all global files ...
Doing so, will also simplify the deployement process !!!! ![]()
=> A single path copy ... is quite easyer as a complicate deployment process ! ![]()
Thanks for your help.
Manu.net
