There is no HEX format dropdown entry for formatting a received string to HEX. TestStand only provides "ASCII String" or "Binary".
It would be very very helpful for developers to have this, as many times one has to command equipment that is controlled with commands written in HEX format and response from devices is in HEX as well.
