NI TestStand Idea Exchange
RyanWright
Improve ControlExecFlow user subproperty documentation
The TestStand documentation describes the ControlExecFlow user subproperty as follows:
"User can control the flow of execution by setting breakpoints, single-stepping, and using the Set Next Step command. User can use the Run Mode command in a user interface. User can use the Run Mode command in the TestStand Sequence Editor but only if the EditSequenceFiles subproperty is also True."
This description should be amended to include the fact that the value of this subproperty also enables or disables options in run-time error dialogs (Retry, Ignore, Abort, and Break).  TestStand users will see run-time error dialogs with different options based on the value of this subproperty.
NOTE: The ControlExecFlow user subproperty description can be found in the online help under NI TestStand Environment Reference Help>>TestStand Sequence Editor Menus, Panes, and Windows>>Windows>>User Manager Window>>User and Group Privileges.
2 Comments
HarshaBhushan
Status changed to: Under Consideration
HarshaBhushan
We were not able to verify the behavior you are mentioning. I acknowledge, this post has been open from several years. But do you recollect or can reproduce it and share more details?
