NI TestStand Idea Exchange
russellb
Improvements to API and examples to make it easier to run TestStand Sequences headless from LabVIEW
You can run TestStand sequences headless currently from LabVIEW, but it would be nice to have more detailed documentation and examples on how to do it properly since it is not straightforward.  There are some end users that do not need to see the TestStand execution in the operator interface and just want to run a sequence without showing all of the TestStand UI components.
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
2 Comments
bienieck
Active Participant
If you need headless execution you can fork my incomplete CLI and try to make it more mature.
https://github.com/425J/TestStandCLI
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
HarshaBhushan
Status changed to: Under Consideration
