NI TestStand Idea Exchange
--thatguy
Integrate Diff Merge Utility into Sequence Editor
TestStand File Diff and Merge Utility is not very useful for code reviews on its own.  It seems adequate for notifying the user that a sequence was added, however from the tool itself the user cannot actually review the newly added or removed sequence's contents.  Why is there no + on the item tree to go deeper.
Alternatively:
If I have to right-click a sequence and select "Go to location" then why bother with the separate tool to begin with?  Why isn't the diff utility integrated into TestStand's sequence editor itself?  Seems like a side-by-side comparison within Sequence Editor would allow a reviewer to poke and prod around all the hidden settings that are often missed using the existing utility.
1 Comment
HarshaBhushan
Status changed to: Under Consideration
