It would be nice if there were an easy means of programmatically loading a database schema for result processing.
Here's my context for asking:
We have a custom database schema that must be loaded on all of our stations and we'd prefer that it "just works" when our customized database result processing plugin is loaded.
I managed to accomplish this by studying the format of TestStandDatabaseSchemas.ini and writing a parser to insert our schema as necessary. This was a bit painful, though, and the possibility of the format changing without notice has crossed my mind.
Thanks as usual to the R&D team. (Assuming this idea gets some traction!
Kind regards,
Mr. Jim
