If you are using a custom environment file for TestStand 2016 and later, it would be great if, on startup, the splash screen indicated the loaded Env file name and path.
As you can see below, in our custom TestStand RTOI we are showing the loaded environment file on the splash screen when it loaded. The TestStand 2019 splash screen is shown for comparison.
