This is a carryover from an earlier idea that got halfway implemented (when the close "x" got moved to the tab).
Right now in TS2025 out of the box sequence editor, if you have a file name that is really long, it just gets truncated in the tab. This makes sense if you have lots of tabs open and are going to be competing for space, but if there are only one or only a few files open, there is lots of extra space that could be used to clarify the file name.
Request is: if you have extra space in the UI for tab sizes to get bigger, make the tabs large enough to display the full file name without truncation.
