1 | |
1 | |
1 | |
1 | |
1 |
At our facility, we have a shared Users.ini file on a network that is used by all test systems in our entire organization (somewhere between 150 and 200 systems). It contains hundreds of different users and many different user groups and its contents change frequently. I recently upgraded to a newer version of TestStand and learned that a single Users.ini cannot be used by multiple versions of TestStand; it can only be used by the version of TestStand in which it was created (or saved, when upgrading).
This is problematic because it means I have to maintain multiple Users.ini files for the different versions of TestStand in use at my facility; whenever I need to make a user change, instead of changing it in one location, I have to make the same change in multiple Users.ini files. Because there is a mixture of TestStand versions in use at my facility, it would be really nice if different versions of TestStand were able to use the same Users.ini file.
