Create a step type that is similar to the multi-numeric limit step type except that it handles the 3 basic data types: Numeric, String, Boolean.
We use sub sequences as our "tests". Because we don't like indentations on our reports and all of the information is relavent to the "test" and we want it grouped it would be nice for the step type to handle those basic datatypes. Also, the report looks messy with all the indentations....granted that could be overcome with some tweaks to the style sheets and such.
You could have a BooleanArray, StringArray and NumericArray as step properties to hold the data source info.
This step type would eliminate all of the test types.
See attachement.
