1 | |
1 | |
1 | |
1 | |
1 |
For debugging pourposec I'd be good if developers can set "do not use this variabe during execution".
Then developers can set this flag on, on the variable which they suspect is not in use during the execution.
If is in use then a message will be displayed.
