1 | |
1 | |
1 | |
1 | |
1 |
When user opens the Offline Processing Utility and at the same time starts to type on the keyboard the user can accidently rename the profile.
(Attached a screen-recording to visualize)
It would be great if there was no selected row or column when starting/opening ORPU. The renaming of the profile disturbs the production since the database logging will not work as expected.
When we start ORPU we already have the '/tray' enabled but somehow its still possible to accidently rename the Profile.
