NI TestStand Idea Exchange
MimiKLM
Programatically accessed feature: Do not compare all results, just log.
Status: Declined
I'm declining this idea due to lack of community support.
Firstly, I've discussed the topic how to programatically disable assesing results here.
I've realised there is no such option. Only one alternative is to swich the comparison type to LOG going thru the steps one-by -one.
It would be good to have the override method not to compare ALLresults in the sequence (during execution).
4 Comments
crossrulz
Knight of NI
You can just set the comparison type of a step to LOG.  You could use an expression to choose between any of the comparison types.
dug9000
NI Employee (retired)
Just want to make sure I understand what you're asking for. You want a way to temporarily (for a particular run) disable the comparison for all of the numeric limit steps in a sequence or sequence file?
MimiKLM
Active Participant
Yes dug9000.
WireWeaver
Status changed to: Declined
