Please make possible to select LV Development System version in similar way as it is possible to select Run-Time Engine.
It also should be available in TS API.
That will allow Test Engineers to use code modules (especially those inside .lvlibps) from different versions.
It would be also useful for to set up desired version of LV for code modules without lack of debugging options of Run-Time Engine calls.
Declining due to lack of community support.
