NI TestStand Idea Exchange
KevRotork
Provide programmatic access to "Python Module Viewer"
Status: New
Recently I was trying to configure the Python Adapter programmatically as part of a package (.nipkg) install to configure TestStand for my operators. I am trying to get programmatic access to the Python Adapter configuration in TestStand to Read and write these values. I am most of the way there, I am just struggling with the "Python Module Viewer" section, getting the Application Path and the Arguments.
Configure >> Adapters >> Python
In TestStand statement step I am doing
RunState.Engine.GetAdapterByKeyName("Python Adapter").asPythonAdapter
And this gives me access to everything else.
Linked to Service Request: 03715194
1 Comment
barneysmith15
As a workaround these settings are accessible through the config file C:\ProgramData\National Instruments\TestStand 2022 (64-bit)\Cfg\Adapters.cfg. It should be possible to edit this file directly - see:
<_PythonAdp_PyModuleViewerAppPath typename='Path' xsi:type='Path' classname='PathValue'>
However this isn't ideal, and given that all the other settings in this menu are accessible through the API it would make sense for this to be available too.
