As in subject:
Now if I put the label inside Selrct-Case-End block the sequence won't run:
Sometimes, you have a lot of cases and the labels would be very useful do describe the cases.
I think they shall be excluded from the the rule that "Only Case blocks can be nested in Select blocks".
I'm declining this idea due to lack of community support.
