NI TestStand Idea Exchange
bienieck
Sequence Editor Public API
Status: New
I would like to suggest adding a public API to the Sequence Editor in TestStand.
Recently, I watched a recording featuring members of the TestStand R&D team, where they explained that users often request various features in the Sequence Editor, even though they already have access to the TS API and TS UI Controls, which allow them to create their own custom user interfaces. Meanwhile, building a custom operating system just to play Heroes of Might and Magic is not standard practice — we buy a fully functional system and run the game on it. Similarly, when writing sequences in TestStand, we purchase a framework along with a ready-made GUI that should provide a comprehensive set of features for creating test sequences. The Sequence Editor is a paid tool, and since users pay for it, it should offer value out-of-the-box without requiring additional development of functionalities that users believe should already be standard.
For this reason, I believe that a paid GUI like the Sequence Editor should be enhanced with an API that allows programmatic control of its functionality.
Examples of functionalities that interest me:
  1. Managing the Output Messages Pane
    • Programmatically clearing messages.
    • Exporting messages to a file.
    • Opening or hiding the pane.
  2. Managing UI Settings
    • Programmatically loading a saved layout.
    • Dynamically controlling the layout during runtime.
  3. Changing Pane Colors
    • Many users currently complain about the lack of a dark mode in TestStand. A partial dark mode can be achieved by changing the background colors of panes. Most (if not all) panes have a Color property that allows color changes, but for some reason, this doesn’t work in the Sequence Editor (I attempted to achieve this by retrieving references to panes through the Application Manager returned by Engine Internal Options, but unfortunately, without success).
These are just examples of features that would be useful to me today. However, long-time TestStand users could likely identify many more ideas for such API. A public API would open the door to much more advanced and personalized use of TestStand, while simultaneously increasing its value for a wide range of users.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
1 Comment
Elaine_R.
Active Participant
as a datapoint - I frequently deploy custom cfg files to attempt to 'preset' some sequence editor characteristics for developers on my team, but it not always guaranteed to work due to installation race-conditions, nor is it easy to figure out what value to edit vs default file set..  being able to have a script that runs 1x on install of my add-on toolkits that goes and fixes the explicit UI settings I wish to adjust (show requirements column, for example), would be great.
Already I do a lot of engine settings on behalf of fellow developers via API calls (configuring search paths and breakpoint behaviors etc) but some settings are unique to UI and not engine, and those are tricker to 'force' for the sake of unified user experience with Sequence Editor.  I would also be happy with some ability to have a %teststandpublic% ini/cfg file that would explicitly override specific default Cfg folder/file values in a reliable manner that I could push during installation, if API too tricky.
