1 | |
1 | |
1 | |
1 | |
1 |
Hi all,
Based on a lot of experimentation, there is no way at run-time to map a logical name to a VISA descriptor in the Session Manager API.
...at least not without adding an entry to NISessionMgr.ini.
[VISA Logical Names] LittleOldComPort = "ASRL1::INSTR"
If I don't do this I can't open an instrument session. I'd still like to use the session manager, but use an external method to map my logical names. (e.g. a database, XML, or something a little less obscure than an .ini file buried in program files)
If the Session Manager is still a supported product, is it possible to add a method to add a logical names for VISA descriptors without using the INI file?
If there's already a way to do this, please excuse my ignorance.
Thanks as always,
Mr. Jim
