NI TestStand Idea Exchange
CyGa
Shortcut to 'Unload All modules'
Status: Completed
When you develop custom step types in LV, you often need to unload all modules in order to modify your LV code (it's faster than going on your step type definition, clic Properties -> substeps -> specify code module -> edit...).
A keyboard shortcut to 'Unload all modules' would be so nice to even speed up the process ! Smiley Tongue
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
9 Comments
crossrulz
Knight of NI
I don't have TestStand with me right now, but isn't it in the File menu?
CyGa
Active Participant
Nope, it's missing ! Smiley Happy
dug9000
NI Employee (retired)
Sequence editor shortcuts are customizable. Right click on one of the toolbars/menubars and choose "Customize...". You can add a shortcut for the unload all modules menu item.
Hope this helps,
-Doug
CyGa
Active Participant
Thanks Doug, it helps !
MimiKLM
Active Participant
Doug, thanks,
However, I think that shall be a global and unified shortcut. It is heavily used function.
HarshaBhushan
Status changed to: Under Consideration
HarshaBhushan
This has been implemented.
HarshaBhushan
Status changed to: Completed
CyGa
Active Participant
13 years after the original request, it took less than 6 days to go from Under Consideration to Done !
Whaou ! It feels like Christmas !
Maybe tomorrow we'll get skins and dark mode also ? Lets dream big !
