NI TestStand Idea Exchange
testergi
TestStand Sequence Grouping
Status: New
We have multiple sequences in a file to perform steps that are common to particular subsystems.  It would be nice to have the ability to group sequences within TestStand.  I could envision this to look like a treeview or folder/file structure within the Sequence Pane.  Currently, we have to use a common naming convention to group the sequences together like below:
GPIO_Inputs_[Seq1]
GPIO_Outputs_[Seq1]
GPIO_Outputs_[Seq2]
Communications_CAN_[Seq1]
Communications_Ethernet_[Seq1]
Communications_Ethernet_[Seq2]
Communications_UART_Port0_[Seq1]
Communications_UART_Port1_[Seq1]
Communications_UART_Port1_[Seq2]
With grouping, it could look similar to below:
Communications
    CAN
        [Seq1]
    Ethernet
        [Seq1]
        [Seq2]
    UART
        Port0
            [Seq1]
        Port1
            [Seq1]
            [Seq2]
GPIO
    Inputs
        [Seq1]
    Outputs
        [Seq1]
        [Seq2]
In addition, there could be a toolbar menu item to switch between showing the grouping or all so you could sort to find
2 Comments
crossrulz
Knight of NI
Duplicate: Allow the grouping of sequences within a sequence file
testergi
Thanks @crossrulz.  Didn't see this.  It appears to be same feature request.  Hopefully this can be added since I'm not the only one requesting.  Thx.
