It would be nice to have a tool such "Trace Toll kit" for TestStand, in order to be abble to view the currently loaded modules.
When you have big Sequences, with many loops, you can get memory problems. ![]()
Then you'll have to play with the load options, the results recording, the on the fly reporting .... ![]()
It should be nice to had a tools which could show us the memory used by every modules, structures, Globals, fileGlobals, parameters, locals ...
So it would be easier to point to the main memory consumers !!!! ![]()
Or better ... let TestStand access the 64bit world
Get rid of the ActivX architecture !![]()
Memory management should not influence Test creation ...
Thanks a lot.
Manu.net
