I would like to show the following problem with the Update Custom Data Type from Cluster tool when updating TestStand container type definition based on LabVIEW cluster.
TestStand creates new container type definition according to the LabVIEW cluster items order. The problem apears after you create the TestStand type definition and then reaorder LabVIEW cluster. After this change in LabVIEW, TestStand will not properlly reorder items in its definition. So for example:
So at the end we have:
IMO items order can be sometimes (if not always) important part of good style. That's why I would like to suggest to update also items order if you select Force Exact Match.
