Currently, for limits in numeric limit tests, I am using TestStand variables, values of which are stored in configuration file. These variables are directly set in limits fields, but units - are specified directly, explicitly.
It would be nice to have possibility assign to Units field variable, which value will be unit itself. Then, units for measurements could be also possible to store in configuration file. But, unfortunatelly, now it is not possilbe to assign to units expression or variable.
