NI TestStand Idea Exchange
CorraDIT
Variables comments shouldn't be deleted if data type is changed
Status: Completed
Fixed in TestStand 2017 under ID 656997.
In TestStand you can create a comment in a variable, but that comment will be deleted even if the data type of the variable is changed. This does not make too much sense because it happens that the customer needs to change  the data type, and then he has to re-write the comment completely. This feedback comes straight from multiple customers and it makes sense that it should be so.
Thank you everybody. Best,
Corrado
3 Comments
WireWeaver
NI Employee (retired)
This was fixed in TestStand 2017. See bug fix list car 656997.
-Trent
WireWeaver
Status changed to: Completed
Scott_Richardson
Active Participant
Scott Richardson
https://testeract.com
