I am trying to edit step variable properties from step to step.
I edit Step.Foo.Bar.Bing.A in the first step.
I click to the next step, it also has Step.Foo.Bar.Bing.A in it, so I edit that value.
I click to the next step, it doesn't have that variable, so I see nothing.
Click to the next step. @#$%@#$. Expand Foo. Expand Bar. Expand Bing. Edit variable A
Click to next step. Still expanded. Edit variable A
click to next step. No variable matching that value.
Click to next step. @#$%@#$%. Expand Foo. Expand Bar. Expand Bing. Edit variable A
This constant Expand the tree is really annoying. I'd love to be able to set an attribute of a container to say "always expand this completely whenever It shows up", or a sequence editor wide configuration of "always expand all properties when you browse to them" which would work fine unless you have "show hidden properties" enabled, and then you have the whole Step.TS.* tree visible, so maybe a "expand all custom properties" or "expand all non-hidden properties" or something like that. Or maybe a way to click on the "+" expanding symbol for that node in the property browser that would completely expand that node
I'm declining this idea due to lack of community support and availability of the workaround above.
