NI TestStand
关于软件的匹配问题及NI板卡与硬件的连接问题
大家好:我现在做的工作是:ECU的测试工作,思路是在simulink中建立模型,然后与labview连接,同时利用NI板卡发出与simulink中模型对应的模拟和
数字信号。将这些信号给ECU后,再将ECU的输出信号采集进来,进入到simulink模型中,形成循环。
问题一:simulink软件,labview,simulation interface toolkit ,采用什么版本,它们之间可以联合使用?
问题二:NI板卡和ECU的连接在软硬件上需要做哪些工作?如何连接起来?
谢谢各位!
(3,961 Views)
your post translated (google tool)
Hello everyone: I now do is: ECU's testing program, idea is to create in the simulink model, and then connect with labview, while taking advantage of NI card issued by the simulink model in the corresponding simulation and
数字信号。 Digital signals. 将这些信号给ECU后,再将ECU的输出信号采集进来,进入到simulink模型中,形成循环。 These signals to the ECU, the ECU then the output signal acquisition came in into the simulink model, form a cycle.
问题一:simulink软件,labview,simulation interface toolkit ,采用什么版本,它们之间可以联合使用? Question one: simulink software, labview, simulation interface toolkit, adopted version, the joint between them can be used?
问题二:NI板卡和ECU的连接在软硬件上需要做哪些工作? Question 2: NI board and the ECU connection to what needs to be done on the hardware and software work? 如何连接起来? How do I connect?
谢谢各位! Thank you!
Kudos!
You probably should post this to the LabVIEW forum.
regards
Ray Farmer
Regards
Ray Farmer
(3,952 Views)
