NI TestStand
-17500 System Our of Memory Exception
I am seeing strange behavior when I first start TestStand. I am getting an error -17500 'System Out Of Memory Exception was thrown' when executing the 'Create Clypeum Container Client' step in the sequence 'Clypeum-CreateCyberObject' in the sequence. Here's the kicker: I only see this error when I try to run TestStand through a LabWindows/CVI GUI. I do not see this error when running TestStand from the Sequence Editor I am using TS 2017 and CVI 2017. I am running the Parallel model. When I look at the Windows Task Manager Performance I do not see any memory issues. I have uninstalled and reinstalled TS and CVI to no avail. I am hoping someone else may have experienced this problem or have an idea of what the possible culprit is. I am running out of options.
I have attached a screen shot of the Run-Time Error window.
(1,156 Views)
Hi GavinChen,
This error can be occurred by the TestStand configuration files going corrupt.
You should remove the files found and reboot the systems. Try to go through this article for completing it with step-by-step guidance.
Regards)
(1,115 Views)
