NI TestStand
17500 error, synchronization manager connection lost
Does the error happen when you enqueue the structure or does it happen after 10 minutes regardless? Is there error only on the remote side?
-Doug
Message 11 of 12
(758 Views)
Reviving an old topic ...
We have the same error now in a different situation. We have a system with two 3D sensors connected to a PC via Ethernet-TCP/IP. We had crashes (system level exceptions) from the processing of the sensor data which killed the entire TestStand process. We then separated the processing for the two sensors between the main TestStand process and a RemoteEngine on the same computer. And now we experienced frequent "sychronization manager connection lost" errors.
Is it possible that the load on the Winsock stack due to the sensor data affects the synchronization manager connection? Is there a way to diagnose that or to reconfigure a timeout etc.?
Peter
Message 12 of 12
(691 Views)
