NI TestStand
-18370 error, scc system has not been initialized
I'm getting the error in the subject when choosing the menu source control/scc provider options.  I am using perforce, and I have a workspace open with projects and files.  Also, when going to configure/station options/source control, I do not see perforce in the drop down menu.  Is there perhaps a module I missed when installing teststand?  I know I've used this in the past but stopped when I realized the directories in the workspace were not auto-populating, limiting it's usefulness.  I went back to using P4V.  But now I am using a workspace for deploying teststand and would like to get source control working again.  Any ideas?
David J.
(4,723 Views)
David,
You need to download and install the Perforce SCC Plug-in.  The plug-in is no longer installed with the P4V client.
To install it, do the following
1. In the Perforce Downloads page, select the tab "Browse by Component"
2. Then, click on Plug-ins & Integrations
3. Finally, click on SCC Plug-in
After you intall the SCC plug-in, restart TestStand and you should see the Perforce in the drop down menu.
Hope this helps,
Jose
(4,715 Views)
Thanks for the reply, I forgot to post back here but I was never able to find this plugin.  It seems on their site there are several called P4SCC, for different things other than teststand.  Do you see it?  Can I bother you to possibly provide a link?  I'd appreciate it.  Thanks
David J.
(4,659 Views)
Accepted by topic author david_jenkinson
I found this link: http://maillist.perforce.com/perforce/downloads/component.html
From TestStand help: TestStand integrates with any SCC system that supports the Microsoft SCC interface.
The Visual Studio SCC plug-in should work.
Jim
(4,644 Views)
I finally found it, seems to work, thanks
(4,641 Views)
