NI TestStand
-19000 General Error for missing block Diagrams
I have a coworker who is having difficulty building a disc using a Teststand deployment utilitiy. We use Teststand 2014 SP1, and Labview 2015 SP1.
We use the same Deployment utility across all of our development computers, and I have checked to verify the settings are the same across them. The install works without issue on my computer, as well as the computer of a third co-worker, even if we copy the project's file over.
The error we are getting is:
Error: General Error (-19000)
Labview cannot compile one or more VIs because they do not have block diagrams.
Invoke Node in AB_Build.lvclass:Copy_Files.vi ->AB_Build.lvclass:Build.vi->AB_API Do Two Step
Build.vi:4020001->AB_API
Build.vi:4700001->NI_AB_API_Build.lvclass:Build.vi->NI_AB_API_SDIST.lvclass:Build.vi->SDBuildClass_2013,lvclass:Build.vi->Build Distribution - TestStand.vi->Build VI Distribution 2010 - TestStand.vi->Build VI Distribution 2010 - TestStand.vi.ProxyCaller
Method Name: Compiler: Compile App Context
I looked online and could not find anyone with a similar error. The closest I found was an error people found related to Actor, and I used the solution there to clear the Compiled Object Cache, but this did not work.
(510 Views)
Have you tried mass compiling your code modules with LabVIEW directly?
(476 Views)
I hadn't. The computer's been taken by IT to try and install on a different laptop. They'd tried reinstalling on this one before without success.
If it continues to fail when they are done I'll try mass compiling.
(460 Views)
We got the laptop back, the new one has the same issue. I tried mass compiling the code modules. That process completed successfully.
However, the same error is still occurring when we try to build from the deployment file.
(421 Views)
Still strange.... do you happen to know what exactly IT did? Did they only install Windows or the NI Toolchain as well?
(403 Views)
