NI TestStand
2 D arry logging into CSV file
Hi ,
I am getting the data in 2 dimensional array .How to log this array into CSV file.
Or Do i need to create Labview Vi and call that in Teststand?
Or we have any direct method calling from Teststand.
(4,372 Views)
Not sure what data you are talking about.  Is it just some general data?  Or is it your result list?
The best is probably using a code module (i.e. LabVIEW) then call that from TestStand.
You can generate a property object file using just TestStand but that won't be the csv format that you are looking for.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,368 Views)
