NI TestStand
3rd party software vendor need copy of TestStand to troubleshoot
I am having an intermittent problem using TestStand to access (via COM server) another software (SmartBear TestComplete). This issue appeared when we upgraded the TestComplete software version. We have exhausted all our solutions thus far and still have same issue. The software vendor request if hey can get copy of TestStand to troubleshoot on their end.  What's the best way to do this?  Are there vendor to vendor cross testing platforms?
ph2
(4,531 Views)
A couple options:
They can always use a trial version.  I believe it lasts 45 days.
Or there is what's called a Debug TestStand License.  It is cheaper than the development license but has most of the capabilities.  The agreement is that you will only use it for debug.
http://www.ni.com/teststand/deploy-compare/
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,502 Views)
Thanks, that's a good idea! Regards, ph2
(4,500 Views)
