NI TestStand
55pcs DUT test at the same time
Hi Experts,
Now I want to use teststand to test about 50pcs DUT boards with MODBUS communication,but don't know how to do at the beginning.
First,computer(master)will assign the slave address to all DUTs by the way slave address+SN.
My problem is how to do test all DUTs at the same time.
How to scan the serial number of each DUT,then test them,program how to manage them,thanks
(3,475 Views)
Testing all the 50 DUT can be done by selecting the parallel model or Batch Process Model.( refer TS help).
You will need to explain your hardware setup more.
For example - scanning of serial number ( how do you plan to do it ?Is it manual or automated?If automated how many scanners do you have which runs simultaneously)
(3,459 Views)
