NI TestStand
A line of code that did not port from TestStand 2017 to 2019 32-bit.
The attached document describes how a particular line of code, see below, no longer works in TestStand 2019.  The attachment also describes how it was used.
RunState.Caller.Locals.ResultList += Locals.ResultList
Any help would be appreciated.
(1,905 Views)
Hi cct3,
Can you post a sequence File that shows the problem?
Anand Jain
(1,868 Views)
Attached is a sequence file that I got from this forum a couple of years ago and worked fine until updating from Test Stand 2017 to TestStand 2019-32bit.  The attached sequence file shows the problem in SequenceFilePostStepFailure, Cleanup.  I did observe that by changing the problem line of code
from
#NoValidation(RunState.Caller.Locals.ResultList) += Locals.ResultList
to
#NoValidation(RunState.Caller.Locals.ResultList += Locals.ResultList)
It now seems to work again.
(1,816 Views)
