NI TestStand
A way to modify the ResultProcessing.cfg file outside of TestStand?
All,
I'm looking for a way to change the style sheet path one time (not hard code it in NI_ReportGenerator.seq), would anyone know of a way how to do it with a vi or something to that affect?  The goal is to initially setup a tester (remotely, I will not be on site to set this), but not hard code them to this one stylesheet.
I'm using TestStand 2012
Bill
John 3:16
(3,860 Views)
The file is an xml text file. If your style sheet values are sufficiently distinct, it shouldn't be too hard to just find and replace the text.
The file is also a TestStand ProperyObjectFile. ResultProcessing.c has code that modifies it using the TestStand API. However, that requires TestStand to be installed and is not nearly as simple as finding and replacing a text string.
(3,846 Views)
