NI TestStand
API Property or Method to determine Position and Size of TestStand UI
I'm looking for an API property or method which returns currently position and windows size of UI.
Thank you in advane.
Kind regards
Christian Dietz
Christian
Test Engineering
digades GmbH
www.digades.com
(4,232 Views)
TestStand UserInterface is mostly developed using LabVIEW, you can use PanelBounds and other property.
are you trying to find TestStand Sequence Editors Panel datas ?
Thanks & Regards
Varaprasath M
Certified LabVIEW Architect
Certified TestStand Architect
(4,193 Views)
