NI TestStand
Abort or Terminate Step
You can put the IVI-stuff and the sequence which is about to abort the IVI-session into two different executions, so you always should be able
to terminate them with terminate execution. The question is if it´s good practice to just kill the IVI-session execution instead of calling IVI-Abort and close the session
the way it is intended to be closed.
M. Brauner NIG
Message 11 of 11
(808 Views)
