NI TestStand
Access Step Parameter
I'm trying to dynamically create a sequence file using the TestStand API,Version 3.5.
The application is written in Visual C++. Adding steps to a sequence is no problem
but accessing the step-specific properties is what I can't figure out to do. The following
code snippet adds a Wait-Step and then tries to configure it for a 2 second wait by
editing the property TimeExpr.
TS::SequencePtr sequence;
TS::StepPtr step;
TS:: PropertyObjectPtr propobj;
// insert 2 second wait
step = engine->NewStep("None Adapter", "NI_Wait");
stepName = "waiting...";
step->Name = (_bstr_t)stepName;
propobj = step->AsPropertyObject();
propobj->SetValNumber("TimeExpr",0,2.0); // exception occurs
propobj->Release();
sequence->InsertStep(step, 0, (TS::StepGroups)0);
Unfortunately I always get an exception when setting the property.
Does anyone know how to do that?
Thanks.
Mike
(3,161 Views)
You need to use SetValString as the TimeExpr is a string property
Regards
Ray
Regards
Ray Farmer
(3,156 Views)
